Changing dependent variable
Posted 2012年3月14日 GMT+1 22:16 Heat Transfer & Phase Change Version 4.2 3 Replies
I am working with a 2D heat transfer model for a solid cylindrical conductor. The dependent variable is the temperature throughout the 2D cylindrical cross section (shaped as a circle) , which is calculated based on the heat balance equation (taking into account heat gain from conduction and solar radiation as well as heat losses from convection and radiative cooling). I would like to modify the model such that the conductor core temperature be set (to 80degC, for example) and the current be calculated. In other words, I am trying to calculate the conductor's current carrying capacity for a series of set parameter values. Do you have any insight on how I can get this done? I tried changing the dependent variable of my model, but it seems fixed to the temperature.
Sonya
Sonya
3 Replies Last Post 2012年3月15日 GMT+1 14:54
