Assistance needed
Kevin Ngangoum Wanche
Hi, i have 2 heat generation equations containint temperature T as variable. eqn 1= 8.93310^22exp(-16246.317/T[1/K]) being active in the temperature range from 90-120°c eqn 2= 2.09410^22exp(-16246.317/T[1/K]) being active in the temperature range frorm 120-170°c.
How can i enter these two equations in my general heat source term field so that each equation is active throughout its temperature region.
Regards
1 Reply Last Post 2020年10月21日 GMT+2 16:36
Posted: 4 years ago 2020年10月21日 GMT+2 16:36
You can embed Boolean quantities in your expressions. For example,will evaluate to 1 if a is greater than b, and 0 if a is not greater than b. So you can write expressions like:. This will evaluate to 6 if a is greater than b, but only 1 if a is not greater than b. You can create similar expresssions involving T in your problem.
You can embed Boolean quantities in your expressions. For example, (a>b) will evaluate to 1 if a is greater than b, and 0 if a is not greater than b. So you can write expressions like: MyVar=1+5*(a>b). This will evaluate to 6 if a is greater than b, but only 1 if a is not greater than b. You can create similar expresssions involving T in your problem.
