4 years ago
2020年11月2日 GMT+1 05:22
Updated:
4 years ago
2020年11月2日 GMT+1 05:23
Dear Harsh,
Coupling Solid Rotor to Beam Rotor is not straight forward becuase of both modeled in a different referece frames. The Solid Rotor is modeled in a corotating frame and the Beam Rotor is modeled in a stationary frame. Thus coupling also involves frame transformation of the displacements as well as finding the correct map location on the solid. Attached is an example of one such coupling to help you with the set up process. Note that Weak Constraint nodes are used to set up the connection between both. For finding more details, you can write to us at support@comsol.com
Thanks and regards,
Prashant Srivastava
Dear Harsh, Coupling Solid Rotor to Beam Rotor is not straight forward becuase of both modeled in a different referece frames. The Solid Rotor is modeled in a corotating frame and the Beam Rotor is modeled in a stationary frame. Thus coupling also involves frame transformation of the displacements as well as finding the correct map location on the solid. Attached is an example of one such coupling to help you with the set up process. Note that Weak Constraint nodes are used to set up the connection between both. For finding more details, you can write to us at support@comsol.com
4 years ago
2020年11月2日 GMT+1 07:52
Thank you so much Prashant for the valuable reply. Sir can you please tell what these weak constraints are doing exactly and how they work. Or if you can plz tell me a better way to have more such insights on such methods or couplings. Thanks.
