Blood flow in a Cerebral Aneurysm
Posted 2020年12月2日 GMT+1 17:111 Reply
Good morning, I'm simulating the blood flow in a brain aneurysm. I made a 2D geometry as if I were considering the central slice of the 3D structure (figure1), where the internal domain is blood and the two external domains are the artery. I set the following boundary conditions: I consider a laminar flow, with a pulsatile flow rate at the inlet as in figure 2 and at the outlet with zero static pressure. For the material properties I inserted a blood with 1060kg/m³ density and a dynamic viscosity of 0.0036 Pas, while the artery properties are in figure 3. The study selected is 'FluidSolid Interaction, Fixed Geometry'. I did a stationary study (with all default parameters) but there is the following error: "Failed to find a solution. Maximum number of segregated iterations reached. Returned solution is not converged. Not all parameter steps returned."
if someone can help me, I will be grateful. Thanks a lot.
