Rotated system in 2D simulation
Posted 2020年12月31日 GMT+1 02:45Piezoelectric Devices, RF & Microwave Engineering, GeometryVersion 5.3a2 Replies
I am interested in simulating the cross section (2D) of a piezoelectric device, with an arbitrary rotation of the material's crystal axes. The process is simple enough in 3D simulations, using Euler angles. In 2D, however, the "rotated system" behavior is slightly less clear. For clarity, I will refer to the "global" coordinates as those corresponding to how the model is viewed on my screen -- X is left to right, Y is up and down, and Z is into/out of the screen.
The desired outcome is to have the material X axis aligned with the global Y axis, and rotate the material Y and Z axes around the global XZ plane.
The "rotated system" option only allows a rotation "about the out-of-plane axis", which at first glance seems unable to do what I want (which would require rotating around the vertical axis/global Y). If I understand correctly, this is also independent of which axis I choose as "out-of-plane".
Is this actually a limitation of the 2D rotated system option in 5.3?
Thank you!
