Magnus Ringh
COMSOL Employee
4 years ago
2021年3月3日 GMT+1 15:06
Hi Amartya,
This error occurs because you are using the optional third argument to therealdotoperator in in an unintended way. From the COMSOL Multiphysics documentation:
realdot(a,b,jaclevel)
Thejaclevelargument controls Jacobian contributions of therealdot(a,b)operator and can have the following values:
- −1: (default) Jacobian contributions in the assembling only if splitting of complex variables in real and imaginary part is active for the Study
- 0: no Jacobian contributions
- 1: always Jacobian contributions
In your model, you have defined the variablenEzasintop1(realdot(emw.Ez,emw.Ez,emw.Ez))/A, which is an incorrect use of the syntax with three input arguments.
Magnus Ringh
Hi Amartya, This error occurs because you are using the optional third argument to the `realdot` operator in in an unintended way. From the COMSOL Multiphysics documentation: `realdot(a,b,jaclevel)` The `jaclevel` argument controls Jacobian contributions of the `realdot(a,b)` operator and can have the following values: * −1: (default) Jacobian contributions in the assembling only if splitting of complex variables in real and imaginary part is active for the Study * 0: no Jacobian contributions * 1: always Jacobian contributions In your model, you have defined the variable `nEz` as `intop1(realdot(emw.Ez,emw.Ez,emw.Ez))/A`, which is an incorrect use of the syntax with three input arguments. Best regards, Magnus Ringh
