determining the local area change
Posted 2021年3月12日 GMT+1 10:13 Structural & Acoustics Version 5.5 5 Replies
Hello, we would like to determine the local area change of a deformed membrane (e.g. a spherical balloon which is blown up from r1 to r2 = 2r1 would have an area change of (2r1/r1)^2 = 4 on each point of the surface. An arbitrary object could exhibit different local area changes throughout the surface). "Include geometric nonlinearity" is activated.
Generally, the area change can be calculated out of the deformation gradient F using Nanson's formula. This involves an inversion and transposition of F, however the expression field only allows the entry of single components of F, e.g. FdxX, which would make the insertion of the whole formula quite hard. Is there any other way of inserting a matrix operation as expression without using individual components?
Or is there already another method implemented for determining the local area change? I was looking at the ratio of meshvol_spatial/meshvol, as it seems that evaluating meshvol_spatial on a surface yields the mesh area. Could anyone confirm if that's a valid approach?
Thanks a lot!
