2012年5月24日 GMT+2 13:26
I'm astonished you do not have any prescribed displacement nodes for your ALE, everything seems moving. A velocity of "0" does NOT mean its necessarily fixed.
Wha not start with the sloshing tankl example of the model library, replace the gravity generator by your moving wave-boom and then at the end, once you have waves, add your floating object
2012年5月24日 GMT+2 13:46
Hi, thanks for your quick respond
But if I use the slooshing tank how should I make the floating object move? Is it determined in the ALE, like prescirbed mesh displacement or is it something else?
And what is the gravity generator in the slooshing tank, we have worked a lot with it but we did not make any progress, that is why we tried another approach.
Another question: we manage to solve the ODE ydtt=0 if we use tw studies and solve the problems separetly, solving laminar flow and moving mesh in study 1 and the global ODE in study 2, but then the answers do not seem to be connected and we can not make the ponton move anyway. Is there some way we can connect them, so that in the result it takes the both solutions from the two studies?
Thank you for considering our questions
2012年5月24日 GMT+2 14:08
my suggestion was to first get the waves generated by the moving submerged boom (that is how I interprete it, then add the floating ponton. But anyhow you need gravity to counter react with the boyance force, if your object is floating then you have a force equilibrium.
What you cannot simulate easily, is the appearance of "air" under the ponton, as this reppresents a change in topology and that COMSOL (nor any other FEM programme I know about) cannot handle automatically. But perhaps with a levvel set 2 phase approach its also possible, but that is a step further.
My suggestions, take one step at the time get first your waves running as wanted, then add next tstep ;)
