Robert Koslover
Certified Consultant
3 years ago
2021年7月7日 GMT+2 16:49
Updated:
3 years ago
2021年7月7日 GMT+2 16:50
Hmm. I'm not sure that's necessarily the best way to deal with vaporization, but... perhaps you could simply define thematerial propertiesto be afunction of temperature, and employ a step function in that definition, such that for T>T_vaporization, the material properties become the same as your computational background space (e.g., air, vacuum, or whatever applies in your case). This wouldn't delete themesh. But I doubt you would really want to delete the mesh anyway. Rather, you probably want the material to be replaced by whatever takes its place following vaporization, right? So I'd leave the mesh alone and let the material properties change. Others here may have different (and quite possibly better!) suggestions, so I encourage them to comment!
Hmm. I'm not sure that's necessarily the best way to deal with vaporization, but... perhaps you could simply define the *material properties* to be a *function of temperature*, and employ a step function in that definition, such that for T>T_vaporization, the material properties become the same as your computational background space (e.g., air, vacuum, or whatever applies in your case). This wouldn't delete the *mesh*. But I doubt you would really want to delete the mesh anyway. Rather, you probably want the material to be replaced by whatever takes its place following vaporization, right? So I'd leave the mesh alone and let the material properties change. Others here may have different (and quite possibly better!) suggestions, so I encourage them to comment!
Henrik Sönnerlind
COMSOL Employee
3 years ago
2021年7月8日 GMT+2 09:57
Robert's suggestion is close to how theActivationfeature inSolid Mechanicsworks: When the material is not active, the stiffness is set to a very small value.
Henrik Sönnerlind
COMSOL
Robert's suggestion is close to how the *Activation* feature in *Solid Mechanics* works: When the material is not active, the stiffness is set to a very small value.
3 years ago
2021年7月8日 GMT+2 10:41
Thanks Roberts for the suggestion.
If i will use Air properties after Vapourization temperature , then in that case i don't get deformed geometry. Kindly give some solution to get deformed geometry.
Thanks in advance
Regards Anshu Sahu
>Hmm. I'm not sure that's necessarily the best way to deal with vaporization, but... perhaps you could simply define the *material properties* to be a *function of temperature*, and employ a step function in that definition, such that for T>T_vaporization, the material properties become the same as your computational background space (e.g., air, vacuum, or whatever applies in your case). This wouldn't delete the *mesh*. But I doubt you would really want to delete the mesh anyway. Rather, you probably want the material to be replaced by whatever takes its place following vaporization, right? So I'd leave the mesh alone and let the material properties change. Others here may have different (and quite possibly better!) suggestions, so I encourage them to comment! Thanks Roberts for the suggestion. If i will use Air properties after Vapourization temperature , then in that case i don't get deformed geometry. Kindly give some solution to get deformed geometry. Thanks in advance Regards Anshu Sahu
3 years ago
2021年7月8日 GMT+2 10:42
What are the other means to get deformed geometry in case of laser ablation.
>Robert's suggestion is close to how the *Activation* feature in *Solid Mechanics* works: When the material is not active, the stiffness is set to a very small value. What are the other means to get deformed geometry in case of laser ablation.
