3 years ago
2021年8月1日 GMT+2 11:34
Updated:
3 years ago
2021年8月1日 GMT+2 18:18
Hello Niraj,
In the model builder, for each bubble :
- define a named selection
- define a domain integration operator and sets its domain of application to the named selection you just created. Default names will be
intop1andintop2but you may change it to something more explicit
- create a variable
volume_1 = intop1(2*pi*r)
Hence, you are integrating the function2*pi*rwhererdenotes the radial coordinate of your axi-symmetric problem. Without the axial symmetry, you should integrate the constant function1instead. I would not be surprised to learn that COMSOL already takes care of the2*pi*rfactor for you, so you should check with a simple geometry (such as a cylinder) which of these two integrands gives the correct result.
Hello Niraj, In the model builder, for each bubble : * define a named selection * define a domain integration operator and sets its domain of application to the named selection you just created. Default names will be `intop1` and `intop2` but you may change it to something more explicit * create a variable `volume_1 = intop1(2*pi*r)` Hence, you are integrating the function `2*pi*r` where `r` denotes the radial coordinate of your axi-symmetric problem. Without the axial symmetry, you should integrate the constant function `1` instead. I would not be surprised to learn that COMSOL already takes care of the `2*pi*r` factor for you, so you should check with a simple geometry (such as a cylinder) which of these two integrands gives the correct result.
