Periodic Boundaries in 3D :: # of Vertices Needed?
Question: When mapping source vertices to destination vertices of a boundary in 3D is it sufficient to only map 3 vertices of boundary that has has more than 3?
Thanks in advance ~
1 Reply Last Post 2012年6月19日 GMT+2 22:08
Posted: 1 decade ago 2012年6月19日 GMT+2 22:08
normally for a 2D to 2D mapping you need 3 vertices, origine, X-direction, Y-direction, for full 3D you need the last Z-direction hence a 4th vertex
Hi normally for a 2D to 2D mapping you need 3 vertices, origine, X-direction, Y-direction, for full 3D you need the last Z-direction hence a 4th vertex -- Good luck Ivar
