License error -5
Hi, I'm practicing the hot water injection simulation using Heat transfer in porous media & Subsurface flow modules. When I tried to run the geothermal doublet example (https://www.comsol.com/model/geothermal-doublet-29751) the error message shows:
Error in multiphysics compilation. Could not obtain license for 'Line Heat Source 1'. Property requiring product: Specify heat source radius.
Required product: Heat Transfer Module. License error: -5. No such product exists.
However, there is Heat Trasnfer Module installed on the computer, and I am able to select and use the "Heat transfer in Porous Media" Interface in the "Heat Transfer" module. Also, I am not able to see the "Heat Source Radius" checkbox, though the user's guide states that there should be one.
Does anyone know if there's something else I should purchase? I have no idea if my current Heat Transfer Module is the full version or not.
1 Reply Last Post 2021年9月6日 GMT+2 23:54
Posted: 3 years ago 2021年9月6日 GMT+2 23:54
Updated: 3 years ago 2021年9月6日 GMT+2 23:55
I suggest you submit your question directly to Comsol Support. https://www.comsol.com/support . You can also check on your licensed products by clicking File --> Licensed and Used Products.
