MUMPS allocation factor increased
Is this harmful and if so how to avoid it?
4 Replies Last Post 2021年12月26日 GMT+1 15:34
Posted: 3 years ago 2021年12月9日 GMT+1 14:43
In itself, it is not harmful, more than that the factorization of the stiffness matrix is somewhat slower because of repeated reallocations of memory.
But in practice, this is almost always caused by an underlying problem in the physics, which makes the prediction of the structure of the system of equations problematic. For example, you often see this when there is severe ill-conditioning, or when there are excessive deformations in a solid mechanics problem (e.g elements turning inside out).
Henrik Sönnerlind
COMSOL
In itself, it is not harmful, more than that the factorization of the stiffness matrix is somewhat slower because of repeated reallocations of memory. But in practice, this is almost always caused by an underlying problem in the physics, which makes the prediction of the structure of the system of equations problematic. For example, you often see this when there is severe ill-conditioning, or when there are excessive deformations in a solid mechanics problem (e.g elements turning inside out).
Posted: 3 years ago 2021年12月20日 GMT+1 09:43
Updated: 3 years ago 2021年12月20日 GMT+1 09:48
Thank you very much Dr Sönnerlind! But why is this warning together with that of inverted elements never seen in lower versions?
Posted: 3 years ago 2021年12月20日 GMT+1 22:21
Can you please elaborate the last question a bit more?
Henrik Sönnerlind
COMSOL
Posted: 3 years ago 2021年12月26日 GMT+1 15:34
In comsol versions 3.5, 4 etc, there's no such warning as inverted elements.
>Can you please elaborate the last question a bit more? In comsol versions 3.5, 4 etc, there's no such warning as inverted elements.
