3 years ago
2021年12月14日 GMT+1 11:10
Hi, the best is that you turn on "Equation View" (in the display options or in your Preferences) and look into the formulas, most of the energy variables are fields depending on (t,x,y,z) ("t" might not be applicable in your case, it depends on the solver being used) hence must be integrated over your domains. Some are total values (it's in the name and the description) hence are already integrated, mostly over the full defined model.
You will also find more info in the doc under the respective physics chapters.
Have fun COMSOLing Sincerely, Ivar
Have fun COMSOLing,
Sincerely,
Hi, the best is that you turn on "Equation View" (in the display options or in your Preferences) and look into the formulas, most of the energy variables are fields depending on (t,x,y,z) ("t" might not be applicable in your case, it depends on the solver being used) hence must be integrated over your domains. Some are total values (it's in the name and the description) hence are already integrated, mostly over the full defined model. You will also find more info in the doc under the respective physics chapters. Have fun COMSOLing Sincerely, Ivar
3 years ago
2021年12月15日 GMT+1 08:15
Updated:
3 years ago
2021年12月15日 GMT+1 08:16
Hi Ivar, thank you very much for ur reply. I still couldn't find the physical formulas for the energie densities in the results so far. In the appendix there is a screenshot where I'm searching for those values. Maybe I missed something or I was searching in the wrong place. Yours sincerely, Max
3 years ago
Updated:
3 years ago
2021年12月15日 GMT+1 08:56
3 years ago
2021年12月15日 GMT+1 19:20
Try printing out a report, I usually use intermediate. You will find full expressions for everything.
