Finding the principal strain along the direction of the force applied
For a stationary static study, I apply a body load to the model. I then want to find the max strain at a point with respect to the direction of the force application. Exporting the data for solid.ep1, solid.ep2, solid.ep3, and its respective component directions (solid.ep1X, etc.), I am thinking I can create the vector of the principal strains and then use external math for solving the component of one vector along another to find the amount of strain along the direction of force applied. My question is whether solid.ep1, and the other principal strains are with resepect to the global axes of x, y, and z in COMSOL?
4 Replies Last Post 2022年3月3日 GMT+1 14:51
Posted: 4 years ago 2022年2月17日 GMT+1 15:51
The orientation vectors, (solid.ep1X, etc.) are expressed in the global directions, yes.
However, there is something strange with the question, or at least the terminology. The three principal strains have certain orientations, computed from the full strain tensor. There cannot be anything like "principal strain along the direction of the force applied", unless by some coincidence, one of the principal strains happen to be oriented in the load direction.
If you are interested in the direct (or normal) strain (as opposed to shear strain) in a certain direction, the easiest option is to select a coordinate system coinciding with the load in the Linear Elastic Material. Then the local strain tensor has the orientations you are looking for.
You can also use the Matrix Transform feature under Definitions, to perform arbitrary rotations of tensors.
Henrik Sönnerlind
COMSOL
The orientation vectors, (solid.ep1X, etc.) are expressed in the global directions, yes. However, there is something strange with the question, or at least the terminology. The three principal strains have certain orientations, computed from the full strain tensor. There cannot be anything like "principal strain along the direction of the force applied", unless by some coincidence, one of the principal strains happen to be oriented in the load direction. If you are interested in the direct (or normal) strain (as opposed to shear strain) in a certain direction, the easiest option is to select a coordinate system coinciding with the load in the Linear Elastic Material. Then the local strain tensor has the orientations you are looking for. You can also use the Matrix Transform feature under Definitions, to perform arbitrary rotations of tensors.
Posted: 4 years ago 2022年2月17日 GMT+1 22:48
Henrik, Thanks for the answer. I am intersted in the strain in a certain direction (that being the direction the force is applied). Can you give me a little more instruction on how to "select a coordinate system coinciding with the load" so the strain values I attain for the strain tensor has the orientation along that direction? I appreciate the help.
Posted: 4 years ago 2022年3月2日 GMT+1 22:33
Henrik,
Any chance you could provide some information on how to use the Matrix Transform feature under Definitions? My thought would be to transform the strain matrix to the system that aligns with my force vector. However, I don't understand where in the Matrix Transform feature I input a transform matrix or some "transform rule"
>The orientation vectors, (solid.ep1X, etc.) are expressed in the global directions, yes. > >However, there is something strange with the question, or at least the terminology. The three principal strains have certain orientations, computed from the full strain tensor. There cannot be anything like "principal strain along the direction of the force applied", unless by some coincidence, one of the principal strains happen to be oriented in the load direction. > >If you are interested in the direct (or normal) strain (as opposed to shear strain) in a certain direction, the easiest option is to select a coordinate system coinciding with the load in the Linear Elastic Material. Then the local strain tensor has the orientations you are looking for. > >You can also use the Matrix Transform feature under Definitions, to perform arbitrary rotations of tensors. Henrik, Any chance you could provide some information on how to use the Matrix Transform feature under Definitions? My thought would be to transform the strain matrix to the system that aligns with my force vector. However, I don't understand where in the Matrix Transform feature I input a transform matrix or some "transform rule"
Posted: 4 years ago 2022年3月3日 GMT+1 14:51
Updated: 4 years ago 2022年3月3日 GMT+1 14:52
Hello Coleman,
To request support from COMSOL staff, please use www.comsol.com/support/ .
Hello Coleman, To request support from COMSOL staff, please use www.comsol.com/support/ . Best regards, Jeff
