How to know when the system reaches steady state?
Posted 2022年2月17日 GMT+1 09:00Heat Transfer & Phase Change, Heat Transfer, Studies & SolversVersion 5.63 Replies
I am solving a "heat transfer in solids" problem (only conductive heat transfer) with time-dependent solver. Heat dissipation is pulsed and on/off periods are in microseconds.
I've solved the model with stationary solver by taking average of the heat dissipation. For instance, heat dissipation is 100W with a duty cycle of 40%, which makes 40W average heat dissipation. By solving the system with 40W heat dissipation by using stationary solver, I have the value for steady state.
However, when I try to solve the system with real on/off heat dissipation value, I need to use time dependent solver. However, temperature increase is extremely slow since pulse time is around 20 microsecs on/30 microsecs off. If the system reaches steady state after 10 seconds, for instance, it makes 10000000 microsecs which requires incredibly high number of timesteps to solve.
How do I determine or estimate total time for the system to reach steady state? Any suggestions? Thank you for reading and help.
Sincerely,
Orcun
