Nagi Elabbasi
Facebook Reality Labs
2012年7月23日 GMT+2 20:06
There could be something wrong in the way you define the coupling between the 2 shells and the solid cylinder. That can cause no coupling and hence the separate eigenmodes.
Nagi Elabbasi
Veryst Engineering
Nagi Elabbasi
Veryst Engineering
2012年7月24日 GMT+2 12:26
Hi Nagi, thanks for your reply. Please could you explain a bit further? I have added a prescribed displacement constraint on the base edge of the two columns in solid mechanics physic and set the value equal to the displacement values of the shell physics (u, v and w).
Nagi Elabbasi
2012年7月25日 GMT+2 15:33
Hi Rachel,
Conceptually what you’re doing seems correct. What expressions do you use to set the displacements on the base edge to be equal to those of the corresponding shell edge? Do you use a mapping operator? You can also look at the displacement results to check if these prescribed conditions are setup correctly.
Nagi Elabbasi
Veryst Engineering
Hi Rachel,
Nagi Elabbasi
Veryst Engineering
2012年7月25日 GMT+2 17:10
Hi Nagi,
I have simply set a prescribed displacement on the edge with u2 = u, v2 = v, w2 = w. I'm not sure what you mean by a mapping operator, sorry. I have plotted a 2D line graph of the edge using solid.u2 and shell.u adn the graphs plot on top of each other. I've attached a model.
Rachel
Hi Nagi,
Rachel
Nagi Elabbasi
2012年7月25日 GMT+2 18:37
Hi Rachel,
Actually you have the displacement condition defined properly. I thought the shell and solid do not share the same geometry which would have required some kind of Model Coupling.
The reason you’re not seeing the coupling is that the solid is much stiffer than the shell and is fixed at most of its boundaries. I tried one variation where I reduced the solid’s modulus to 1 GPa and excluded Face 3 from the Roller 1 displacement condition and then I see the coupling clearly.
Nagi Elabbasi
Veryst Engineering
Hi Rachel,
Nagi Elabbasi
Veryst Engineering
2012年7月26日 GMT+2 15:56
Thank you for your help Nagi. It's great to know I am on the right tracks. My next step is to add water above the ground going part way up the column to see how the vibration of the columns affects the liquid.
2012年11月28日 GMT+1 16:43
Hello,I am working with a problem concerned about shell-solid interaction,I built a model (in the attachments), I want to calculate the eigenfrequency of this model ,but I am not sure whether it is reasonable,I donnot know whether I should add any conditions?
