Henrik Sönnerlind
COMSOL Employee
4 years ago
2022年3月17日 GMT+1 13:42
Make sure that Equation View is active. Under, for example, a Weak form PDE node, look up Weak Expressions in Equation View. There, you can modify the Integration order text field.
Henrik Sönnerlind
COMSOL
Make sure that *Equation View* is active. Under, for example, a *Weak form PDE* node, look up *Weak Expressions* in *Equation View*. There, you can modify the *Integration order* text field.
4 years ago
2022年3月18日 GMT+1 05:13
Hi Henrik, thanks very much, as I found before, is it only possible in weak form that one can change the integration order? If so, PDE modules except the 'weak form' module show explicit equations while leaving the weak form completely blank, then can we still change the order?
