2012年7月26日 GMT+2 23:23
I'm not by my WS so I cannot have a look at your model, but I suspect that for t=0 your initial conditions are too far from a solution. Have your tried to define first a steady state solver to get a coherent flow& T distribution at t=0 and use that as initial conditions for your time series ?
2012年7月26日 GMT+2 23:29
Hi Ivar
I ran a steady state to get the initial temperature, pressure etc, to be assigned into the subsequent transient state. Previously with 4.2a, I successfully ran a similar transient state (with less BCs and some unrealistic parameters), but it got kind of crashed when I imported to 4.3, therein I rebuild a new one, run a stationary state, then a transient state. Stationary state returned good result but when the transient state is running infinity...
On the other hand, I am wondering if I should modify anything at the solver i.e. segregated step, initial time step etc..
Thanks for your time, Ivar!
regards
Liwah
Hi Ivar
regards
Liwah
2012年7月27日 GMT+2 09:51
I too rebuild my models, as I do not fully trust the translations, COMSOL is still evolving quite a lot between versions, as new improved features arrive, and its rather quick to rebuild a model. What you are saying confirms what I read in the release notes, that the solver settings have somewhat been adapted. But I have not had enough free time to test this out yet in v4.3.
If you model is not too large, I can only suggest to add a "fully coupled" node to the solver sequence as for me tis often solves quicker, but requires more RAM. It' then only to disable the fully coupled npode to revert back to COMSOLs default settings. Pls note that once you manually add or adapr the solver sequence, COMSOl flags the sequence as user defined, and I have noticed that it does not lways adapt the solver sequence automatically , if you change elements and nodes in your model, so you should check t elogic manually after modifying your model.
Another point is the order of the physics and the segregated solver steps, sometimes the default order of solving the dependent variables is not optimum, and it's worth to reorganise (up/down) the order in which you solve the variables. This requires manual tweaking and your knowledge of the process going on: which variable is the "master, which one the "slave", even if they are coupled.
2012年7月27日 GMT+2 12:48
Hi Ivar
many thanks for the advise.
I added a 'fully coupled' node, the 'segregated' node was greyed out by itself then. I moved 'fully coupled' node a level up (above 'iterative' node), run! the computation takes less RAM in my case (<= 2GB, if I use 'segregated' node, it takes <=10GB). It is still running and I am not sure if it will turn out to be another infinity.
May I check with you if I should stick with 'iterative' or 'direct' under 'time dependent solver'? I read some threads saying that 'iterative' runs faster than 'direct', but some threads say the otherwise. I am pretty confused.
I shall keep it posted! Many thanks again, Ivar!
regards
Liwah
Hi Ivar
