Auxiliary Sweep in Submodel study in Submodelling.
Hi everyone,
The model contains a hole inside a rectangle, and one end of the rectangle is fixed, and from the other end, prescribed displacement is given to the rectangle so that the hole deforms. ( model has the plasticity with large deformation). Now I want to analyze the hole deformation in the submodel study using the general extrusion command; I successfully map the displacement around the boundary of the submodel. But in the submodel, I use elasticity only, and that's why stresses are very large in the submodel. If I use plasticity, then converge errors occur in the submodel. To remove converge error, I want to use prescribed displacement using auxiliary sweep in sub modeling so that the deformation occur in the submodel in steps as in the global model.
Can I do it in the COMSOL? How to do it, please help??
If need then I can upload my model.
6 Replies Last Post 2022年6月30日 GMT+2 15:22
Posted: 3 years ago 2022年6月29日 GMT+2 14:05
You need to use the same parameter (and parameter range) for the auxiliary sweep in both the global model and the submodel.
When you, for the submodel study, set data in the Variables not solved for section, it is important to use Automatic (all solutions) in order to map the results for the corresponding parameter values.
Henrik Sönnerlind
COMSOL
You need to use the same parameter (and parameter range) for the auxiliary sweep in both the global model and the submodel. When you, for the submodel study, set data in the *Variables not solved for* section, it is important to use *Automatic (all solutions)* in order to map the results for the corresponding parameter values.
Posted: 3 years ago 2022年6月29日 GMT+2 14:21
Ok , Thank you very much I will try and inform you.
Posted: 3 years ago 2022年6月29日 GMT+2 14:54
For the global model I given prescribed displacement to the rectangle end as ux= -(dtri1(para)), uy=0 ; where d=0.5mm( max displacement) and para is used in axuliary sweep with range(0,0.1,1). tri 1 is a displacement function (for loading and then unloading) after general extrusion for the submodelling I used prescribed displacement as ux=(comp1.genext1(comp1.u))tri2(para) uy=(comp1.genext1(comp1.v))*tri2(para) with same range of para and tri function. and setting as you said. I still getting errors-- Failed to find a solution for all parameters, even when using the minimum parameter step. Iteration for finding elasto-plastic strain variables did not converge. Geometry: geom2, Domain: 1 Failed to evaluate variable. Variable: comp2.solid2.Fiil11, Defined as:
Am I following you or there is something else you want to say.
Thanks for your valuable suggestions.
For the global model I given prescribed displacement to the rectangle end as ux= -(d*tri1(para)), uy=0 ; where d=0.5mm( max displacement) and para is used in axuliary sweep with range(0,0.1,1). tri 1 is a displacement function (for loading and then unloading) after general extrusion for the submodelling I used prescribed displacement as ux=(comp1.genext1(comp1.u))*tri2(para) uy=(comp1.genext1(comp1.v))*tri2(para) with same range of para and tri function. and setting as you said. I still getting errors-- Failed to find a solution for all parameters, even when using the minimum parameter step. Iteration for finding elasto-plastic strain variables did not converge. Geometry: geom2, Domain: 1 Failed to evaluate variable. Variable: comp2.solid2.Fiil11, Defined as: Am I following you or there is something else you want to say. Thanks for your valuable suggestions.
Posted: 3 years ago 2022年6月30日 GMT+2 11:53
Updated: 3 years ago 2022年6月30日 GMT+2 15:16
I am still facing errors-
                                            uy=0 ;
where d=0.5mm ( max displacement) and para is used in axuliary sweep with range 0,0.1,1). tri1 is a displacement function (for loading and then unloading) and in submodel after general extrusion , I used prescribed displacement as
Am I following you or there is something else you want to say?
I am still facing errors- For the global model I given prescribed displacement to the rectangle end as ux= -(d*tri1(para)), uy=0 ; where d=0.5mm ( max displacement) and para is used in axuliary sweep with range 0,0.1,1). tri1 is a displacement function (for loading and then unloading) and in submodel after general extrusion , I used prescribed displacement as ux=(comp1.genext1(comp1.u))*tri2(para) uy=(comp1.genext1(comp1.v))*tri2(para) with same range of para and tri function. and setting as you said. I still getting errors-- Failed to find a solution for all parameters, even when using the minimum parameter step. Iteration for finding elasto-plastic strain variables did not converge. Geometry: geom2, Domain: 1 Failed to evaluate variable. Variable: comp2.solid2.Fiil11, Defined as: Am I following you or there is something else you want to say? Thanks for your valuable suggestions.
Posted: 3 years ago 2022年6月30日 GMT+2 14:48
Hello Shyam,
While COMSOL employees may participate in the Discussion Forum, users of licenses eligible for support under their institution's license agreement should submit their questions via the Support Center for a response from the Technical Support team.
Hello Shyam, While COMSOL employees may participate in the Discussion Forum, users of licenses eligible for support under their institution's license agreement should submit their questions via the Support Center for a response from the Technical Support team. Best regards, Jeff
Posted: 3 years ago 2022年6月30日 GMT+2 15:22
Ok, Thanks Jeff I already done it, they sent me some links to understand the submodelling in COMSOL, I am working on that. Thanks.
