Henrik Sönnerlind
COMSOL Employee
3 years ago
2022年7月4日 GMT+2 13:32
Updated:
3 years ago
2022年7月4日 GMT+2 13:33
Since you do not have direct control over where the mesh nodes are located unless you actually have a point there, it seems most natural to add a point and use Point Load.
If you do not want to do that (for example because the mesh is imported), you can use Point Load, Free. There, you enter the coordinates of the load application point. If that happens to be the same as the coordinates of a mesh node, then it has the same effect as a force on a node.
Henrik Sönnerlind
COMSOL
Since you do not have direct control over where the mesh nodes are located unless you actually have a point there, it seems most natural to add a point and use *Point Load*.
If you do not want to do that (for example because the mesh is imported), you can use *Point Load, Free*. There, you enter the coordinates of the load application point. If that happens to be the same as the coordinates of a mesh node, then it has the same effect as a force on a node.
3 years ago
2022年7月4日 GMT+2 17:38
Dear Henrik Sönnerlind:
Thanks for your answer!
What's bothering me at the moment is that I'm trying to apply mesh nodal forces, but I think I'm applying a point load through the point load command, and there's a difference between a nodal force and a point load. I would like to ask, how to implement the application of nodal force in COMSOL?
3 years ago
2022年7月4日 GMT+2 17:42
I think there is a difference between nodal force and point load. The point load command and the point load free command in COMSOL are point loads, not nodal forces.
Henrik Sönnerlind
COMSOL Employee
3 years ago
2022年7月5日 GMT+2 07:54
A point load is a nodal force.
Henrik Sönnerlind
COMSOL
