Modelling loudspeaker surrounds; What is your approach?
Posted 2022年7月11日 GMT+2 17:44 Structural & Acoustics, Materials, Modeling Workflow 2 Replies
Hi there,
I am curious to see what other people's approach is towards modelling their transducers surrounds in fluid-strucutre-interaction problems, more especially concerning damping, as that has been somewhat of an unknown to me so far (and has led to uncertainties).
Usually, I start with the data I have about the textile or rubber material used for the surround, which I use to impose the correct density for that domain. An equivalent surround's Young modulus is inferred by tuning the model until a static deflection test simulation matches real measurements. Both of these procedures work well to reproduce the measured resonance frequency. So far, so good.
However, frequency domain simulations, more often than not, present huge surround breakups and a very high Q at the resonance frequency, which differs substantially from measurements. At the moment I can only think this might be related to the damping model (the ones available at Solid Mechanics->Linear Elastic Material->Damping) in use. Usually damping is assumed as a constant (traditional) isotropic loss factor, but to no help. The textile materials we use, in particular, are often impregnated with resins that help them achieve good damping characteristics, which would explain the lack of breakups seen in reality, but which lead me to conclude that what they do is far from traditional damping.
Low values of isotropic loss factors seemingly don't change the simulated FR curves all. High values will merely offset the output curves down, not really addressing the breakups as they're expected to.
Exploring what could happen with the rayleigh model, the effects I could see were not really addressing breakups as much as expected, but the overall output of the modelled transducer was very sensitive to the parameters used, in the other hand. I must say I was not able to explore well enough the other available models just yet.
What would be good suggestions to try next in this sense? TIA.
