COMSOL Employee
3 years ago
2022年7月26日 GMT+2 18:15
Updated:
3 years ago
2022年7月26日 GMT+2 19:59
Hello Dylan,
You can find the exact mathematical definition of the flc2hs function in the Reference Manual for COMSOL Multiphysics version 6.0 on page 357. The idea is that it's a smoothed Heaviside function, with the width of the smoothed region controled by the second argument. Away from that smoothing region, it returns 0 if the first argument is negative, and 1 if it is positive.
In the attached toy model, I use flc2hs to define an inhomogeneous thermal conductivity such that there is an ellipsoidal zone with a low conductivity in the center of the domain and a high conductivity elsewhere, with a smooth transition between the two. After computing the solution, you'll see how that causes the heat flux lines to curve outward to "avoid" the low conductivity chunk, as expected.
Hope this helps.
Hello Dylan,
Hope this helps.
3 years ago
2022年8月23日 GMT+2 12:01
Thank you Jeff, it seems to work very well with the help of your model.
COMSOL Employee
3 years ago
2022年8月23日 GMT+2 15:56
Glad I could help!
Glad I could help!
