About convergence
Now I meet an unfamiliar issue. For the solver I had set the relative tolerance as 0.001 and used the direct solution. As the simulation processed, this value was lower than 0.001, but the simulation could not stop until the Maximum number of iteration reached the setting value (50). Finally it showed that :"Failed to find a solution. Maximum number of Newton iterations reached. Returned solution is not converged.". I can't understand that since the relative tolerance was lower than the setting value why It could not converge. Who knows this answer and help me. Thank you very much!!!
4 Replies Last Post 2012年9月19日 GMT+2 16:41
Posted: 1 decade ago 2012年9月18日 GMT+2 09:21
It is so strange! Previously, if the relative tolerance is lower than the fixed value, the simulaiton will converge and stop. But now......Does anyone know it why? Thank you.
Andrew Prudil Nuclear Materials
Posted: 1 decade ago 2012年9月18日 GMT+2 21:55
Are you sure you are not thinking of absolute tollerances instead of the relative tollerances?
It wouldn't make sense to say something is defined because the absolute error is less than the relative error tollerance. Think about dependent variables less than one. For example, if I am trying to calculate a concentration which is about 1e-6 and my relative error is 0.001 then I need to be converged within 1e-9 not 1e-3.
Another possiblity is that you have set a tolerance factor to a value less than 1 in your solver.
Are you sure you are not thinking of absolute tollerances instead of the relative tollerances? It wouldn't make sense to say something is defined because the absolute error is less than the relative error tollerance. Think about dependent variables less than one. For example, if I am trying to calculate a concentration which is about 1e-6 and my relative error is 0.001 then I need to be converged within 1e-9 not 1e-3. Another possiblity is that you have set a tolerance factor to a value less than 1 in your solver.
Posted: 1 decade ago 2012年9月18日 GMT+2 23:55
Thank you for your response! I am very sure my setting was the relative tolerance and the tolerance factor was 1. I tried again and again, but it still could not converge. Even the previous simulation which was certainly converged can not be converged now. It is so strange....... In addition, the ErrEst was certainly much lower than the fixed tolerance.......but finally showed the simulation could not converge.
Thank you for your response! I am very sure my setting was the relative tolerance and the tolerance factor was 1. I tried again and again, but it still could not converge. Even the previous simulation which was certainly converged can not be converged now. It is so strange....... In addition, the ErrEst was certainly much lower than the fixed tolerance.......but finally showed the simulation could not converge. [QUOTE] Are you sure you are not thinking of absolute tollerances instead of the relative tollerances? It wouldn't make sense to say something is defined because the absolute error is less than the relative error tollerance. Think about dependent variables less than one. For example, if I am trying to calculate a concentration which is about 1e-6 and my relative error is 0.001 then I need to be converged within 1e-9 not 1e-3. Another possiblity is that you have set a tolerance factor to a value less than 1 in your solver. [/QUOTE]
Posted: 1 decade ago 2012年9月19日 GMT+2 16:41
Now I had solved this issue. This is totally because of version! I updated the comsol tool, and then it became right.
Now I had solved this issue. This is totally because of version! I updated the comsol tool, and then it became right. [QUOTE] Are you sure you are not thinking of absolute tollerances instead of the relative tollerances? It wouldn't make sense to say something is defined because the absolute error is less than the relative error tollerance. Think about dependent variables less than one. For example, if I am trying to calculate a concentration which is about 1e-6 and my relative error is 0.001 then I need to be converged within 1e-9 not 1e-3. Another possiblity is that you have set a tolerance factor to a value less than 1 in your solver. [/QUOTE]
