Inverse heat conduction problem - determination temperature-dependent thermal conductivity
I am interesting to solve an inverse heat conduction problem in order to determine the thermal conductivity using Comsol.
The study area is a block and I have the six boundary values and 50 temperature measurements in the area. I suppose that there is not heat generation and temperature doesn’t change (steady-state).
I would like to ask you if the above problem (the determination of thermal conductivity) can be solved using Comsol.
Where can I find more information that will help me with the above problem?
Thank you in advance,
George
2 Replies Last Post 2012年9月19日 GMT+2 15:55
Posted: 1 decade ago 2012年9月19日 GMT+2 13:38
ideally you need the optoimisation module, but if you have only one constant variable you can manage without (less precise mostly still often quite OK) You define your measurement values, and your probe ploints and you create a an error variable eoing My_Error_value = sum of (Tmodel-Tmeasured)^2, then you define a global expression My_Material_k such that My_Error value is "0" or minimum
There is some examples for the HT controlled loop that work in a similar way (see model library)
Hi ideally you need the optoimisation module, but if you have only one constant variable you can manage without (less precise mostly still often quite OK) You define your measurement values, and your probe ploints and you create a an error variable eoing My_Error_value = sum of (Tmodel-Tmeasured)^2, then you define a global expression My_Material_k such that My_Error value is "0" or minimum There is some examples for the HT controlled loop that work in a similar way (see model library) -- Good luck Ivar
Posted: 1 decade ago 2012年9月19日 GMT+2 15:55
Presuming that your conductivity varies spatially, you problem is very similar to this one: www.comsol.com/showroom/documentation/model/4410/ . The Optimization Module is needed to minimize the distance between numerical model and experimental data.
Presuming that your conductivity varies spatially, you problem is very similar to this one: http://www.comsol.com/showroom/documentation/model/4410/ . The Optimization Module is needed to minimize the distance between numerical model and experimental data.
