Mass Concservation in Two Phase Pipe Flow
Hi folks,
I was wondering if there is a way to check if the mass conservation principle is uphold in COMSOL for pipe flow.
I am using glass spheres in water in my simulation and due to some instabilities I have employed some Inconsistent Stabilization, and I am fearful that this might mess with the mass conservation.
Any advice?
Best Regards,
Rui
3 Replies Last Post 2012年12月27日 GMT+1 20:29
Posted: 1 decade ago 2012年9月28日 GMT+2 17:41
Anyone?
Could use some help in this issue.
Anyone? Could use some help in this issue.
Posted: 1 decade ago 2012年9月28日 GMT+2 21:03
Integrate the mass flow rate over the inlet and outlet and check that they are equal. You can do in the Derived Values node under Results.
Posted: 1 decade ago 2012年12月27日 GMT+1 20:29
I did a surface integral across my inlet and outlet. I put fp.rho*v in the integral expression box (where v is the velocity moving perpendicular to the inlet and outlet cross section and fp.rho is the density). The difference between those two results is roughly -0.000802938 kg/s. I then took a volume integral for my air flow domains with fp.rho (density) in the integral expression and got a nearly constant mass of 0.001692 over 600 seconds. Clearly, this is contradictory because the delta in my mass flow rates is large enough to cause a noticeable change in my total mass. Am I using the integration tools wrong here? If not, what could cause this blatant error in COMSOL?
