Failed to find consistant initial values
Posted 2023年2月2日 GMT+1 10:37Fluid & Heat, Studies & SolversVersion 5.61 Reply
The below post is related to anarchived discussion
[start here] The model Im working on has Turbulent SST, Moisture transport in the air and Heat transfer in moist air as physics, and Moisture flow, heat and moisture and NITF as multiphysics couplings. Problem is when I run time dependent, one way with Initialization NIFT, if the time range is (0,0.1,1)s it gives me a result. But when I run the same model for the range of (0,0.1,1)h it says failed to find consistent initial values. I need the study to be done for (9,30[min],16)h. Can someone give me any advice?
