Interpolation function file
Hi people,
in my Heat Transfer simulation I use an interpolation function input with a spreadsheet file. All work OK!
But when I specify the file name and load it, the form change shape: the file name field disappears. So if I wanto to change the file name it is impossible. How can I come back to the file choice?
Thank you at all.
Bye Roberto.
2 Replies Last Post 2012年10月13日 GMT+2 08:51
Posted: 1 decade ago 2012年10月13日 GMT+2 02:26
There 2 two ways: First, do not press "import" button at all. Then simulations will run just fine but the interpolation data won't be saved together with COMSOL model. Second, you can press "Export", save it to a file, and then the file name field appears again.
Posted: 1 decade ago 2012年10月13日 GMT+2 08:51
Thank you Alexander for reply, but I'm hard to understand!
Ok for the first solution, but if I have already imported it is mandatory to use the second.
Now the problem is: where can I find the Export command? In the Settings tab I don't see it, and also right clicking with the mouse in the "Interpolation1" I don't see the command.
Bye, Roberto
Thank you Alexander for reply, but I'm hard to understand! Ok for the first solution, but if I have already imported it is mandatory to use the second. Now the problem is: where can I find the Export command? In the Settings tab I don't see it, and also right clicking with the mouse in the "Interpolation1" I don't see the command. Bye, Roberto
