Setting a maximum limit to a variable
Posted 2023年5月9日 GMT+2 11:31 Fluid & Heat, Computational Fluid Dynamics (CFD), Heat Transfer Version 6.0 2 Replies
I am creating a user-defined variable for calculating pumping power, which will be a function of pressure difference and flow rate. I will use the pressure difference calculated by COMSOL as the input for the function. However, I want to set a maximum limit for the pumping power value, so that it does not exceed a certain threshold. Is there a built-in function in COMSOL that can help me achieve this?
