convert imported *.stl into solid
Posted 2012年10月22日 GMT+2 08:48 Version 4.4 8 Replies
What do I need to do to 'knit to solid' or make the object into a solid as recognized Any direction would help a lot.
Should I maybe open it in a different software and convert it into a solid there?
I mostly use Parasolid, or STEP, as STL is not a true 3D CAD coding, but a layered 2D coding
What have you used finnaly? I have a 3d surface triangular mesh in a .stl file, but I don't know how to make a solid from it, in order to use it as a geometry for my model.
I managed to find a solution. It is not trivial nor free. We can import the .stl file with +CAD (Simpleware), convert it to a mask and then save/export it as a +ScanIP (simpleware) file. Once in +ScanIP we open the file with the mask and we create a NURBS surface from the mask. We can export the mesh in different formats that Comsol accepts. I tried with .igs extension and it worked.
Some references here:
www.comsol.com/press/news/article/117/
www.comsol.com/products/interfaces/simpleware/
First create a volume by Modules->Geometry->Elementary entities->Add->Volume
Then mesh solid by Mesh->3D
Export as .bdf and import in COMSOL under mesh option.
I've checked your procedure and it worked fine.
Thanks for sharing it here.
Suggested Content
- KNOWLEDGE BASE Error: Failed to Connect to Solid Edge
- BLOG How to Build Geometries from Elevation Data to Model Irregular Shapes
- KNOWLEDGE BASE Resolving Gaps and Intersections in Imported CAD Assemblies
- FORUM How to convert a imported line segment into solid object?
- KNOWLEDGE BASE Error: "Out of memory"
