Using Continuation to optimize a value
Hello folks,
I am wondering if it is possible to use the Continuation feature in the solver to optimize a value.
For instance, have a flow in a pipe and using some data like pressure drop, velocity, etc as a reference, and then optimize 2 or 3 empiral constants so they match the data.
Is this possible?
Hope it is clear.
Best Regards,
Rui
3 Replies Last Post 2012年11月7日 GMT+1 19:32
Posted: 1 decade ago 2012年11月7日 GMT+1 19:07
the Solver continuation tab is good to scan some values and to derive some other variables and see how these change (and occasionally identfy a optimum max or min).
Another way is to define a global variable to be minimised such that it represents an error function from some parameter deviation and hence optimise directly onto your desired max-min value. But if you have several variables its better to have the optimiation module, its made specifically for that process
Hi the Solver continuation tab is good to scan some values and to derive some other variables and see how these change (and occasionally identfy a optimum max or min). Another way is to define a global variable to be minimised such that it represents an error function from some parameter deviation and hence optimise directly onto your desired max-min value. But if you have several variables its better to have the optimiation module, its made specifically for that process -- Good luck Ivar
Posted: 1 decade ago 2012年11月7日 GMT+1 19:11
Thank you for your reply Ivar!
But the continuation can use combination of parameters, correct?
Would that work if i defined 5 global variables, for instance?
And how would I define the max and min values? I am bit confused on that part.
Could you provide some more info, please. Or an example in the comsol literature.
Best Regards,
Rui
Thank you for your reply Ivar! But the continuation can use combination of parameters, correct? Would that work if i defined 5 global variables, for instance? And how would I define the max and min values? I am bit confused on that part. Could you provide some more info, please. Or an example in the comsol literature. Best Regards, Rui
Posted: 1 decade ago 2012年11月7日 GMT+1 19:32
You can add several parameters, but you must decide if these are read as column combination, one colun at the time, or as full combinatory selelction.
Chekc ht emodel library and the Forum, the search of a global value such that the model matches a given desired set point is an optimisation often used and described. For 2 its the same, but you need also to give some initial or derivative points to help theslver to find the corect value
Hi You can add several parameters, but you must decide if these are read as column combination, one colun at the time, or as full combinatory selelction. Chekc ht emodel library and the Forum, the search of a global value such that the model matches a given desired set point is an optimisation often used and described. For 2 its the same, but you need also to give some initial or derivative points to help theslver to find the corect value -- Good luck Ivar
