Slip and No Slip
Posted 2012年11月8日 GMT+1 12:49 Computational Fluid Dynamics (CFD), Modeling Tools & Definitions, Parameters, Variables, & Functions Version 4.3, Version 5.2 9 Replies
which will be a suitable option to choose for blood flow in capillaries.
The slip wall condition is for cases where viscous effects at the wall are negligible and/or your mesh size is much bigger than the boundary layer thickness (so you’re not capturing the boundary layer effects anyway). The slip boundary is also the proper boundary condition for symmetry surfaces. You can verify that if you look at the equations COMSOL uses when you select Symmetry boundary condition.
Nagi Elabbasi
Veryst Engineering
no-slip is the fact that a fluid velocity tends to "0" at the solid-fluide interface, noslip there is no fluid-surface friction at all.
Form most fluid problems, at least in laminar no-slip is rather "normal" in turbulent anyhow there are "tricks" being applied in the surface layer regions, but I tend to use no-slip anyhow.
A slip conditions is as a symmetry condition (check the true equations), the wall has no effect on the fluid velocity in planes parallel and close to the wall
You were first this time Nagi ;)
on No slip wall u,v=0 and you have boundary layer
in slip wall normal velocity is zero but the tangential velocity is not zero (v=0,u is nonzero) and you do not have boundary condition.
I have my own question. anybody knows about dp/dx or dp/dy on a slip wall and no slip wall?
L
What about at two liquid interface? suppose air is flowing over a pool. what boundary condition is appropriate at the interface? I think slip boundary condition should be fine. And what there is a species transfer across the boundary?
In this case, it is usually assumed that the tangential components of velocities in two fluids at the interface are equal. This is a kind of "no-slip" condition since the relative velocity of the fluids at the interface is zero but they can both be non-zero (The fluids move together along the interface).
The normal components are also equal unless evaporation or condensation (mass transfer between the fluids) occur.
Amin,
