Relative Tolerance
I have done some simulations and the intial values used are the default ones. I was wondering when does initial values are important? Is it important to set the relative tolerance for a problem involing linear thermoelasticity and heat transfer? Although my simulation converges at much more lower values than the relative tolerance.
1 Reply Last Post 2012年11月12日 GMT+1 20:22
Posted: 1 decade ago 2012年11月12日 GMT+1 20:22
most of the time I'm rather happy with the solver settings, but also, most of the time I use initial values, that I try to set closer to my best guess of the solution, or that I correct after a first run, because the solver converges quicker like that and my results are overall smoother. All default = 0 is a startingpoint, but not always the best for convergence
Hi most of the time I'm rather happy with the solver settings, but also, most of the time I use initial values, that I try to set closer to my best guess of the solution, or that I correct after a first run, because the solver converges quicker like that and my results are overall smoother. All default = 0 is a startingpoint, but not always the best for convergence -- Good luck Ivar
