2012年11月22日 GMT+1 11:08
I'm doing some simulation with coupling between RF and PDE modules, but it's clueless from your description.
2012年11月22日 GMT+1 15:59
Hi Zang,
Actually I want to solve the PDE simultaneously with the electrostatic module i.e I need to solve the following two equations :
Laplacian(V)=u/eps eq(1)
Divergence(DuE)=0 eq(2)
where E = -Gradient(V)
D is a contant, eps is a constant and E is actually a vector having two components i.e Ex and Ey V is the voltage field and u is the space charge density. However when I try to solve these equations simultaneously by using UMFPACK solver the simulations do not proceed and immediately reports an error of non symmetric matrix found. I simply cant understand what is wrong and how to solve this problem?
Hi Zang,
2012年11月22日 GMT+1 16:02
It seems the equation system is not complex. But I'm also not familiar with the error message. Perhaps you can upload the model file? I would like to have a look.
2013年4月11日 GMT+2 15:44
Hello everyone,
I have a convergence problem with modelling of Electrostatics equation coupled with PDE( for charge transport equation). I attached the equations and .mph files.
MODEL : two electrodes placed in domain of air. voltage difference applied. I have to calculate resultant electric field, charge density values and use them to add a body force to laminar flow to simulate plasma.
1. Geometry is simple. Mesh is fine.
2. I tried fully coupled( various damping factors), segregated, parametric sweep of the source term in charge transport equation( which makes it nonlinear) but couldn't get it to converge.
3. I tried using PDEs alone instead of electrostatics,but again same problem ( Plasma Actuator Mod.mph)
Could anyone please help me with way to obtain convergence or any other way to solve the equations attached.
Hello everyone,
9 years ago
2016年12月26日 GMT+1 22:00
You will need to set a voltage as electrical potential in Electronics Initial Values1 (e.g. 1000V).
NK
NK
