Daniel Bertilsson
COMSOL Employee
3 years ago
2023年12月5日 GMT+8 17:57
To get a non-uniform spacing, you can use a Move feature instead of Array. In the x displacement text field, enter for example f({range(0,1,10)}), where f is a function, for example {range(0,1,10)}^2+{range(0,1,10)}. Then use a second Move feature to move the resulting moved objects in the y-direction.
COMSOL Employee
3 years ago
2023年12月6日 GMT+8 05:07
Updated:
3 years ago
2023年12月6日 GMT+8 05:13
Hi Ilan,
For completeness sake, and although it is probably overkill for your needs, I'll mention that you could also use a model method to create your geometry. Seethis blog postfor an example.
A couple of other approaches would consist in using MATLAB and LiveLink for MATLAB (assuming your COMSOL license includes it), or the COMSOL Java API.
But Daniel's approach is by far the simplest one so there's no reason for you to look further if it works for you.
Hi Ilan, For completeness sake, and although it is probably overkill for your needs, I'll mention that you could also use a model method to create your geometry. See [this blog post](https://www.comsol.com/blogs/how-to-create-a-randomized-geometry-using-model-methods/) for an example. A couple of other approaches would consist in using MATLAB and LiveLink for MATLAB (assuming your COMSOL license includes it), or the COMSOL Java API. But Daniel's approach is by far the simplest one so there's no reason for you to look further if it works for you. Best regards, Jeff
3 years ago
2023年12月19日 GMT+8 13:48
Updated:
3 years ago
Thank you both for your responses! I ended up needing MATLAB with LiveLink for a different purpose, so this was an easy problem to start learning it with.
