Change Material Properties based on First Solution
Posted 2024年2月16日 GMT+1 16:40Modeling Tools & Definitions, Results & Visualization, Modeling WorkflowVersion 6.10 Replies
Hello all, I am trying to do a two iteration study in which:
1/First iteration: run a parametric study with a parameter (a) taking values from 1 to 80.
2/ for EVERY value(a) use two Variables from the first study and calculate a NEW value e.g.: A(x,y,z)* b(x,y,z) = c(x,y,z).
3/second iteration:set a specific material property based on the new value c(x,y,z) and run the parametric study again with the same geometry but different physics settings.
So basically the function c has 4 arguments x,y,z and a. If i run the first iteration and export the data then it would have the columns (x,y,z,a=0,a=1,a=2.......a= 80)
If I want to load this result into an interpolation function then i have to specify the (position in file) every time I run the simulation (so 80 times for the second iteration). IS there any way to automate the (position in file) in an interpolation function based on a parametric sweep, if not, is there any way to achieve what's above?
- i do not know how to use Matlab or Comsol Application builder
Hello Hakam Al Zouabi
