Create Probing Surface then Surface Integrate over it
Good evening Ladies and Gentlemen!
I'm working with a 3D fluid flow model, and I want to find the mass flow rate through an arbitrary cross section of the flow. How can I create a surface that can then be integrated across to get mdot = rho*velocity*area? I am easily able to integrate with the "Derived Values" --> "Integration" --> "Surface Integration" command, but I do not know how to create a selectable surface at any arbitrary cross section!
TEB
1 Reply Last Post 2012年12月20日 GMT+1 21:32
Posted: 1 decade ago 2012年12月20日 GMT+1 21:32
easiest, I would say is to define the surface via a Boolean function on a Data Set "cut plane", if you cannot define it front up via a boundary
Hi easiest, I would say is to define the surface via a Boolean function on a Data Set "cut plane", if you cannot define it front up via a boundary -- Good luck Ivar
