time dependent coupled thermal structural with slow & fast pressure & thermal pulses.
I ran a time dependent coupled thermal-structural problem with temperature dependent structural and thermal properties. When the thermal and pressure pulses were ramped up over two seconds no problem.
Identical problem but only over 5 ms for both pulses. Problem only goes to 3.5 ms and then explodes. Any suggestions?
Arthur Rupel
1 Reply Last Post 2013年1月3日 GMT+1 08:25
Posted: 1 decade ago 2013年1月3日 GMT+1 08:25
have you checked your termal gradient at initial t=0 ? and do your mesh correctly resolve the gradients ? This is often forgotten or overlooked and might make the solver fail.
I often runa stationary case to get a coherehnt starting point, then run the time series, or I start from a well known temperature profile and I ramp up (smoothed step operator) the BC flux items
Hi have you checked your termal gradient at initial t=0 ? and do your mesh correctly resolve the gradients ? This is often forgotten or overlooked and might make the solver fail. I often runa stationary case to get a coherehnt starting point, then run the time series, or I start from a well known temperature profile and I ramp up (smoothed step operator) the BC flux items -- Good luck Ivar
