specifying varing coefficient - interpolation function
Posted 2013年1月9日 GMT+1 17:32 2 Replies
Hi all,
I would like to specify varing htc via interpolation function and apply it to a heat flux boundary condition. I am attaching a sample file.
- Model: 2D-axisymetric (i.e.cylinder, mm), heat transfer in solids, and s-s case
- Features: a heat flux boundary condition with heat transfer coefficient varing along line (not as constant). assigned via interpolation function
- Error: Wrong number of function arguments, Number of arguments expected: 1'
I built a simple 2D axisymetric, heat transfer in solids, and s-s case and added a heat flux boundary condition with heat transfer coefficient which is varing along line. An external htc data set was imported using interpolation function under Global Parameters.
t f(t)
1 50
2 52
3 54
399 52
400 50
1) I can see a plot without assiging units, but with units (argument: mm, function: W/(m^2*K)) a horizontal line is only appeared. What should I consider?
2) I am facing the same error message 'wrong number of function arguments' when running the simulation. I believe the number is ok but it repeatedly says it.
Any advice and help will be appreciated,
mg
t f(t)
1 50
2 52
3 54
399 52
400 50
mg
2 Replies Last Post 2013年1月23日 GMT+1 14:57
