Acculution ApS
Certified Consultant
2 years ago
2024年7月8日 GMT+8 15:28
I believe this is for improved accuracy. If certain terms in a equations are emphasized due to a frequency term, it might be beneficial to apply a scaling. You can always set it to 1 and to the default and then compare results across a wide frequency range.
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
2 years ago
2024年7月8日 GMT+8 16:14
Thanks, René. I am not sure I understand how this affects accuracy, do you know where I can read more about this.
I was modelling acoustic resonance and found that the resonance frequency of my system was around 0.5 MHz higher with the scaling set to 1.
>I believe this is for improved accuracy. If certain terms in a equations are emphasized due to a frequency term, it might be beneficial to apply a scaling. You can always set it to 1 and to the default and then compare results across a wide frequency range. Thanks, René. I am not sure I understand how this affects accuracy, do you know where I can read more about this. I was modelling acoustic resonance and found that the resonance frequency of my system was around 0.5 MHz higher with the scaling set to 1.
Magnus Ringh
COMSOL Employee
2 years ago
2024年7月8日 GMT+8 16:20
Hi Peter,
In general, numerical calculations benefit from terms of about equal magnitude. Here is an overview of what's called "error cancellation" (for example, when two terms have markedly different magnitude):https://www.sciencedirect.com/topics/engineering/error-cancellation.
Magnus
Hi Peter, In general, numerical calculations benefit from terms of about equal magnitude. Here is an overview of what's called "error cancellation" (for example, when two terms have markedly different magnitude): . Best regards, Magnus
