computing accurate fluxes with periodic boundary conditions?
Hi everybody,
does anyone know if I can compute the fluxes accurately, as described in the user guide on page 308 ff. and file 0973 from the knowdledge database etc, when using periodic boundary conditions on the respective boundaries? In the descriptions, it is explained only for Dirichlet boundary conditions :( And if you think it should work, should I then use the weak constraint option? (and, how, if you have time to explain?) I model in the PDE mode of version 4.1. with matlab.
All best,
Sabine
2 Replies Last Post 2013年1月26日 GMT+1 01:42
Posted: 1 decade ago 2013年1月25日 GMT+1 16:13
Hi Sabine,
well.. if you know (at least you know where to look for) how to deal with Diriclet BC's, then you have just 2 options left:
- Neumann BC's: in this case what you look for is exactly what you prescribed (trivial)
- Robin BC's: write as follow: ( a*x + b*d(x) ) = f(x)
this is nothing but a combination of the two previous cases. of course you know somehow a, b, f(x). On the boundary you know x from the solution vector, so immediately comes d(x) which is the flux that you want.
since you're working with Matlab this shouldn't require a big effort. I didn't read thourgh the manual, but this is something that you can write yourself directly in Matlab!
Hope it helps!
Mattia
Hi Sabine, well.. if you know (at least you know where to look for) how to deal with Diriclet BC's, then you have just 2 options left: - Neumann BC's: in this case what you look for is exactly what you prescribed (trivial) - Robin BC's: write as follow: ( a*x + b*d(x) ) = f(x) this is nothing but a combination of the two previous cases. of course you know somehow a, b, f(x). On the boundary you know x from the solution vector, so immediately comes d(x) which is the flux that you want. since you're working with Matlab this shouldn't require a big effort. I didn't read thourgh the manual, but this is something that you can write yourself directly in Matlab! Hope it helps! Mattia
Posted: 1 decade ago 2013年1月26日 GMT+1 01:42
another point I have noticed, is that to get good flux values along boundaries, you should ensure your mesh is fine while getting close to this boundary, by using edge pre-seeds, or even a boundary mesh (sometimes the latter requires further tweaking)
Hi another point I have noticed, is that to get good flux values along boundaries, you should ensure your mesh is fine while getting close to this boundary, by using edge pre-seeds, or even a boundary mesh (sometimes the latter requires further tweaking) -- Good luck Ivar
