MAKING STRIATIONS IN A SOLID CYLINDER
how do i make striations in a solid cylinder? I know it should be possible but some how cannot figure out how?
2 Replies Last Post 2013年2月7日 GMT+1 01:32
Posted: 1 decade ago 2013年1月30日 GMT+1 06:52
can you shape the section in a workplane and then extrude (with or without twist) ?
Hi can you shape the section in a workplane and then extrude (with or without twist) ? -- Good luck Ivar
Posted: 1 decade ago 2013年2月7日 GMT+1 01:32
hi,
i tried doing it but it did not help.
Actually what i am trying to do is make invaginations in the side of the cylinder. I revolved a rectangle on y-axis forming a cylinder, but my next step involves placing this cylinder in a system where spheres are embedded into the cylinders including the invaginations
Thank U :)
hi, i tried doing it but it did not help. Actually what i am trying to do is make invaginations in the side of the cylinder. I revolved a rectangle on y-axis forming a cylinder, but my next step involves placing this cylinder in a system where spheres are embedded into the cylinders including the invaginations Thank U :)
