Problem on Analytic function
I want to define analytic function E, which is a function to time, t, but when I want to plot out E(t), there is always a error, which is attached. Who can help me figure out what is the problem? t isrange(0,0.0625,30). thanks
4 Replies Last Post 2013年2月4日 GMT+1 07:03
Posted: 1 decade ago 2013年2月3日 GMT+1 19:13
I do not believe "e" is defined like that (perhaps "e_const" not even sure), have you checked the help function for the build in functions?
I expect to see something like exp(-t) tat should work
Hi I do not believe "e" is defined like that (perhaps "e_const" not even sure), have you checked the help function for the build in functions? I expect to see something like exp(-t) tat should work -- Good luck Ivar
Posted: 1 decade ago 2013年2月4日 GMT+1 02:29
Thanks for your reply.
when I change it to -2*t, it still doesn't work, so what is the problem for the "invalid lower bound error" enclosed in the attachment.
Thanks for your reply. when I change it to -2*t, it still doesn't work, so what is the problem for the "invalid lower bound error" enclosed in the attachment.
Posted: 1 decade ago 2013年2月4日 GMT+1 07:03
for the plot further down on the definition node tabs you need to define the plot limits of "t", I expect then something is wrong there, check the doc
Hi for the plot further down on the definition node tabs you need to define the plot limits of "t", I expect then something is wrong there, check the doc -- Good luck Ivar
