How to rotate a 2D Plot?
I built a model with a 3D geometry. Unfortunately the created 2D plot (postprocessing), which is based on a cut plane, is rotated by 90°. Is it possible to rotate the 2D plot back by 90° or to exchange the axis (x/y -> y/x)?
Thank you in advance!
4 Replies Last Post 2016年9月5日 GMT+2 09:50
Josh Thomas Certified Consultant
Posted: 1 decade ago 2013年2月5日 GMT+1 18:17
Kenji-
When you define your Cut Plane you can define a yx-plane instead of an xy-plane. This should work for you.
Josh Thomas
AltaSim Technologies
Kenji- When you define your Cut Plane you can define a yx-plane instead of an xy-plane. This should work for you. Regards, Josh Thomas AltaSim Technologies
Posted: 1 decade ago 2013年2月5日 GMT+1 18:33
Great! That works for me.
Thank you very much!
Great! That works for me. Thank you very much!
Posted: 9 years ago 2016年9月5日 GMT+2 09:44
Hi!
I'm at loss for how to do this with a general plane type (which I have to use since the plane I want to plot has it's normal pointing towards x^-y^).
Thanks in advance for answer!
BR
Magnus
Hi! I'm at loss for how to do this with a general plane type (which I have to use since the plane I want to plot has it's normal pointing towards x^-y^). Thanks in advance for answer! BR Magnus
Posted: 9 years ago 2016年9月5日 GMT+2 09:50
I made a quick breakthrough just after posting :)
A parameterized surface did the trick.
BR
Magnus
xkcd.com/979/
Hi!
BR
Magnus
I made a quick breakthrough just after posting :) A parameterized surface did the trick. BR Magnus https://xkcd.com/979/ [QUOTE] Hi! I'm at loss for how to do this with a general plane type (which I have to use since the plane I want to plot has it's normal pointing towards x^-y^). Thanks in advance for answer! BR Magnus [/QUOTE]
