Edgar J. Kaiser
Certified Consultant
2 years ago
2024年11月24日 GMT+8 01:06
Juan,
depending on the frequency range you have in mind the AC/DC or RF modules are needed. In case you want to measure material data such as conductivity and permittivity, which are required for a model, a vector impedance analyzer is needed.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Juan, depending on the frequency range you have in mind the AC/DC or RF modules are needed. In case you want to measure material data such as conductivity and permittivity, which are required for a model, a vector impedance analyzer is needed. Cheers Edgar
2 years ago
2025年2月10日 GMT+8 18:39
Juan,
Cheers Edgar
Edgar, one more question, if I know the axial and radial conductivity value of a material, how can I introduce it in this matrix, I don't know the order it should take, for example if the axial value is 1 and the radial value is 2, how should the matrix look like considering that I am working in 2D?
>Juan, > >depending on the frequency range you have in mind the AC/DC or RF modules are needed. In case you want to measure material data such as conductivity and permittivity, which are required for a model, a vector impedance analyzer is needed. > >Cheers >Edgar Edgar, one more question, if I know the axial and radial conductivity value of a material, how can I introduce it in this matrix, I don't know the order it should take, for example if the axial value is 1 and the radial value is 2, how should the matrix look like considering that I am working in 2D?
Edgar J. Kaiser
2 years ago
2025年2月10日 GMT+8 23:46
Hi Juan,
you enter the x-, y- and z-component into the matrix diagonal. You must use expressions that transform the cylinder coordinates into cartesian coordinates. I recommend to define variables in order to keep the entries in the matrix short.
It is quite straightforward but maybe somebody can suggest a more elegant method.
Cheers Edgar
Edgar J. Kaiser
www.emphys.com
Hi Juan, you enter the x-, y- and z-component into the matrix diagonal. You must use expressions that transform the cylinder coordinates into cartesian coordinates. I recommend to define variables in order to keep the entries in the matrix short. It is quite straightforward but maybe somebody can suggest a more elegant method. Cheers Edgar
