Unexpected discrepancy when solving a plate bending problem using weak form PDE module
Posted 2025年1月15日 GMT+8 10:39Equation-Based Modeling, Modeling Workflow2 Replies
Hi there,
I am trying to solve the deformation of a boundary clamped thin circular plate bearing uniform pressure. This problem possesses axisymmetry, but I also tried to solve it in 2D space (model 2D) besides in the 1D axisymmetric space (model 1D) for validation. Please note thatonly the Kirchhoff-Love plate model is employed in model 2D, model 1D, and the analytical solution.
The value of bending stiffnessis assigned directly, instead of calculated through Young's modulus, so
and Poisson ratio
in this case are considered independent.
It seemsthere is something wrong with model 2D: i) the model is hard to converge; ii) even if it converged, the deflection would belargerthan theoretical prediction and show dependence on Poisson ratio. To be specific, the center deflection predicted by model 2D monotonically decreases toward the analytical solution as Poisson ratio decreases from 0.5 to -1.
By comparison,model 1D works well. It agrees with the analytical solution regardless the value of Poisson ratio.
I would appreciate if you could give me a hint.
HC L
If we take a=2, q=1, D=1000, and an arbitrary nu, the center deflection is theoretically 2.5e-4.
details about model 2D (the picture is also attached below):
details about model 1D (the picture is also attached below):
The .m files of the two models are attached
Post was updated on 2025.01.16 to provide more details.
Updated on 2025.01.22 to attach the .m files of the two models.
