The returned solution does not converge
Posted 2025年1月17日 GMT+8 11:28Electromagnetics, Studies & SolversVersion 6.21 Reply
Hello, I would like to ask for some advice. I am currently using the electromagnetic field physics field to build an antenna with a frequency set at 4 GHz. I want to observe the antenna gain of this antenna at 4 GHz, but during the calculation process, it gets stuck at 70% and the calculation becomes very slow. Eventually, it reports an error. I coarsened the mesh division, but the result is still the same. I also modified the relative tolerance in the solver, but the result remains the same. Could you please tell me what factors might be causing this? Error: -The steady-state solver 1 (sol1/s1) failed to find a solution. The linear iteration diverged. The returned solution does not converge. Not all parameter step sizes were returned. How to solve it ? Thank you very much!
