Modeling Issues in Post-Tensioned Prestressed Concrete Beam with Bond-Slip Interactions
Posted 2025年2月25日 GMT+8 23:12Materials, Studies & Solvers, Structural MechanicsVersion 6.32 Replies
Model Setup
I built a 1/4 geometric model of a post-tensioned prestressed concrete beam for a four-point bending test.
Key details
Prestressing tendons differ from ordinary rebars: Their ends are anchored to the beam’s end faces via anchorage devices. To simulate this, I applied a "Pinned" boundary condition in the Truss interface.
Concrete models
Study 1: Ottosen failure criterion
Study 2: Damage-plasticity coupled model
Bond-slip interactions
(defined inEmbedded Reinforcement under Multiphysics Coupling)
Spring connection between ordinary rebars and concrete (setting the bond slip model);
Spring connection between prestressing tendons and concrete (setting the bond slip model);
Rigid connection between prestressing tendons and concrete.
Results & Issues
Study 1 (Ottosen model)
Bond-slip for rebars + rigid connection for tendon and concrete (ignoring "Pinned" condition)
Result: Load-deflection curve (yellow) aligns with test data (blue) in overall trend and ultimate deflection but overestimates ultimate load.
However, it's better to include both bond-slip model and "Pinned" ends for tendon, but this causes computational nonconvergence.
Figure: http://easylink.cc/qcg2c5
Study 2 (Coupled damage-plasticity model)
Same bond conditions as Study 1
Result: Premature non-convergence; green load-deflection curve shows unrealistically small deflections. Theoretically, this should better match tests than Study 1.
Questions
(1) Constraint Conflict: Is it impossible to simultaneously apply bond-slip interaction and "Pinned" boundary condition to prestressing tendons? Do these settings conflict fundamentally?
(2) Coupled damage-plasticity Model Instability: Why does the damage-plasticity model converge poorly and produce unrealistic results compared to the Ottosen model?
(3) Segmented Tendon Modeling: Goal: Divide the prestressing tendon into three segments:
Segment A: Rigid connection to concrete
Segment B: No surrounding concrete (free/unbonded)
Segment C: Bond-slip interaction
Implementation Options:
-Split tendon geometry into segments and assign different Embedded Reinforcement settings (rigid/spring connection)
-Use parameter modulation (e.g., set parameter c0 and c_h for bond-slip inEmmbedded Reinforcementto 0 in Segment B via position-dependent variables) Which method is more stable and physically consistent?
