Recovery after power failure
Hello. I recovered a static, parametric study which failed after a power cut. I could see the parametric solutions and wanted to continue the study after the power came back on. I recovered the mph file from the Comsol sidebar the opened the parametric study and pressed the 'Continue' button with the option to keep the existing solutions. After the resumed parametric study had completed, the 'Parametric Solutions' only contains the solutions after when the continue button was pressed.
I can see the original solutions in the parametric study, however, in the parametric list, only the ones after the continue button was pressed can be accessed as a parametric solution.
Is there a way to combine the studies inside a Parametric Solution so I may plot the data?
Neil Pearson
0 Replies Last Post 2025年3月25日 GMT+8 04:16
Hello Neil Pearson
