Standard Deviation Over a Volume
Hello all,
I would like to calculate the mean andstddev values of concentration over a Domain. I know how to do the mean (Derived Values > Volume Average), but not the standard deviation.
I have looked at some solutions on this forum, but I am hoping someone with more experience than I could explain the simplest route for doing this calculation. The more info the better, as it seems many others have had the same question without an answer.
Thank you in advance for your help!
2 Replies Last Post 2025年4月10日 GMT+8 02:55
Posted: 2 years ago 2025年4月10日 GMT+8 01:47
Updated: 2 years ago 2025年4月10日 GMT+8 02:23
Hello Carl,
Seemy answer hereand the attached file (The problem has a trivial analytical solution for which the standard deviation can also be analytically computed, as a check).
Hello Carl, See [my answer here](https://www.comsol.com/forum/thread/306483/how-to-get-temperature-standard-deviation?last=2022-05-11T02:52:46Z) and the attached file (The problem has a trivial analytical solution for which the standard deviation can also be analytically computed, as a check). Jeff
Posted: 2 years ago 2025年4月10日 GMT+8 02:55
Jeff,
This solution appears to work for my model. I appreciate you taking the time to provide the file. It was helpful to see an example.
All the best,
Carl
Jeff, This solution appears to work for my model. I appreciate you taking the time to provide the file. It was helpful to see an example. All the best, Carl
